racerwalsh big bore 65mm t.b. is really a 94-95 5.0 mustang t.b!!!!!
check this out i was looking at this thing ang pulled out the tb from a 95 5.0 i part and was surprised. i think $470 is steap for this with a adapter!! a lil fab work an you could make your own adapter
heres the link and a pic of mine. this also comes on certain 5.0 t birds too
http://racerwalsh.zoovy.com/product/...ttle_Body.html
Here is how did it on mine. No adapters etc. http://s177.photobucket.com/albums/w...n75/?start=100 Sleeper Inc. Next time at j-yard I will look for you one. Seen several just was in hurry. I will get you one and me one for the MGB
to match the size of the TB opening and you can use a 93 tempo tps but you will need to cut the sides off and brace it with a plate to adjust it.you will need your old tps connector to make a pig tail and then it should work fine after you drill the holes.
