help with strokers
Old 02-19-2004, 06:44 PM
mkspeed26
mkspeed26's Avatar
Default help with strokers
i was thinkin about my engine buildup while searchin through summit today and i found that i could actually make a 331 stroker for $600 instead of buying a kit for $1300 because i will be buying an engine rebuild kit whick includes bearing, pistons, etc. and there would be no point in buying pistons if i need to turn around and sell them anyways. i started punching numbers and some of the number were a little weird.
so here is the question- are the pistons in a 331 stroker the same as the pistons for a 306??
mkspeed26 is offline
Old 02-20-2004, 07:27 PM
mkspeed26
mkspeed26's Avatar
Default RE: help with strokers
anyone??
Old 02-20-2004, 09:18 PM
vfast
I ♥ Acer
vfast's Avatar
no....they are shorter
vfast is offline
Old 02-21-2004, 11:02 AM
n2o44
n2o44's Avatar
the compresion height
n2o44 is offline
Old 02-21-2004, 09:23 PM
mkspeed26
mkspeed26's Avatar
you guys know where i could get some?? i didnt see any in summit or jegs. thanks.
Old 02-21-2004, 10:34 PM
vfast
I ♥ Acer
vfast's Avatar
you can get a kit from dss
vfast is offline
Old 02-21-2004, 10:48 PM
mkspeed26
mkspeed26's Avatar
i know. i would like to build my own though.
Old 02-21-2004, 10:53 PM
hotrodman
I ♥ Acer
hotrodman's Avatar
say speed 26..just order the kit get your block bored ,,assy.yourself...
hotrodman is offline
Old 02-22-2004, 08:33 PM
Moosetang
Moosetang's Avatar
Do you have to bore with the 331?
Moosetang is offline
Old 02-22-2004, 09:07 PM
mkspeed26
mkspeed26's Avatar
moose- yes you need to bore it to get the full 331. all kits come with .030 over pistons, so you need to bore it unless you get differant pistons. if you dont bore it it will give you 327 cid.
hotrod- by "building my own" i want to choose my own parts for the kit. i can actually save money by picking out the parts myself
Brett Ludlow
09-23-2015 06:59 AM
EASTIDEE123
09-14-2015 03:52 PM
YoungStangsMan
09-05-2015 07:01 PM
kevin02
39
05-22-2004 01:39 PM
95_GT_Stang
04-10-2004 04:39 PM
Quick Reply: help with strokers
