Urgent... No turn signal??????
RE: Urgent... No turn signal??????
The one behind the glove box is for the hazards.
What i need, and you may, is a multifuction switch. I also posted about this and im waiting to find a 5.0 with the switch so i can try it.
Good luck and post if you find a solution.
For the record in my 88GT the hazard flasher is monted on the back side of the fuse panel on the drivers side. You must remove 2 screws and flip it half way to access it. The turn signal flasher in my car is located almost directly below the steering column just slightly to the left about 1" . The flasher is mounted by a push on style tab. I pried it loose with a screw driver. The new flasher DOES BLINK FASTER than the old one. Probably oem flashers were slower. That was the original flasher in my car. 18 years!!!!! So new one is definately better!!!!!!
jwog666
12-27-2021 08:09 PM
lincolnshibuya
12-08-2015 04:37 PM
breaking
10-02-2015 01:27 PM
logan409
09-26-2015 07:43 PM
