5.0 Running Weird bogs and backfires
I have a 1989 Mustang 5.0 LX and it runs fine when i first start it and drive it but when it warms up after its been running for a while it doesnt idle good and doesnt have nearly as much power. Anyone had this problem? I've read maybe i should clean my mass air flow and TPS but any info woudl be great thanks everyone
RE: 5.0 Running Weird bogs and backfires
check to see if your distributor cap is cracked.....i had the same problem but it only did this when it was wet or humid out..turned out that when it is humid moisture got inside and wet the contact points....ran fine when it was dry out
Yeah getting new plugs tomorrow, replaced the cap/rotor and wires last summer so i wouldnt think it would be that but id have to check it out. thanks guys
Some autoparts stores can do a bench test on the TFI module to see if it is bad. You'll need a special tool to take the TFI module off. It's a real thin walled socket/hand tool, I bought one at Advanced auto for less than 5 bucks I think.
Good Luck
Good Luck
