track or street Trick Flow intake?
#31
RE: track or street Trick Flow intake?
I live in an area where big 4X4 trucks are the "cool" thing to have, and I might have a hard time finding someone like that. I live in Kentucky, and if anyone knows of a good/trustworthy place...let me know ASAP!!! I'm ready to start building SOON!!!
#32
im taking mine to blus oval classics in kingsport tenn. ride revolutions is good too but b/o/c only build mustangs and they have a dyno too. they have a website too. blueovalclassics.com.
#33
i think you would be better off with the TRACK heat since you are running a 347 . i am running the STREET heat kit on a 302 and i have said on this forum before i really like this trick flow kit . if i had my time to go over i would buy the SAME street heat kit again.
#34
Seriously, once you get the kit installed, you will have to set the idle up higher anyways. My car idles at about 1000 RPM.. It only takes a flick of the throttle to hit 1500rpm even in a stock car, 1500 rpm is nothing. You must think about it, and plan out your combo.
My street heat was good for beginning the build up, but now that I am hitting over 105mph in the 1/4 the motor is starving for more air faster! So out with the E303 and the Street heat, and in with the F303 and the Track heat...
#35
you should look into the tf cams.
ORIGINAL: 91hatchgt
#37
ORIGINAL: ikeybmg
ORIGINAL: 91hatchgt
#38
check out comp extreme energy cams. they can give you alot more options on cams. pretty much match you up with any setup. or a custom grind from them can match any setup. lunati or crane are good too.
Luke9222
10-22-2015 11:55 PM
mungodrums
10-07-2015 04:01 AM
09-08-2015 11:50 AM
09-01-2015 08:16 PM
kawiguy827
09-01-2015 07:09 PM
