will new gears mess up speedo?
04-05-2006, 02:45 PM
i've seen gear replacement kits that offer an included speedo correction computer, is this necessary? how much do new gears throw off your speedo?
04-05-2006, 02:57 PM
RE: will new gears mess up speedo?
yes you do need em... not sure how much they will throw it off
04-05-2006, 03:00 PM
The Rogue Mod
The higher away from the original ratio the more it will be off.
04-05-2006, 03:10 PM
As PRO50SC said it depends on the gear ratio. For the corrected speedometer gear see
HERE
04-05-2006, 03:31 PM
so if I use a 3.73 in my '95 GT then how far off will i be?
04-05-2006, 04:13 PM
Ya it depends on what gears you buy but you can find a speedo gear for about 8$ but that may depend on where you live.
04-05-2006, 05:00 PM
i'm not even sure where the speedo gear is located. is it easy to swap out? is it better than getting an expensive programmer? (i have a 95 GT)
Bokeo
10-10-2015 08:28 PM
breaking
10-02-2015 01:27 PM
KingRando
10-02-2015 08:06 AM
uedlose
The Racers Bench
10-01-2015 08:31 PM
junior04
09-28-2015 10:53 AM
