e303, Afr 165's, Trick flow intake
With this combo, how much horsepower does it produce over a stock 94gt 302. Also, from your opinions, would you rather get the trick flow street heat, or trick flow track heat with this combo?
RE: e303, Afr 165's, Trick flow intake
probably around 320-340 at the fly wheel. about +100hp, of course thats with headers and good tb ect. ect.
you want the street version, track is ultra high rpm monsters that get up over 6000 rpm / or big breathing strockers
you'll probably loose some low end torque with the track intake
I made 290 HP and 306 ft lbs to the wheels with an AOD Mustang using the E303, FRPP Cobra 1.7 rockers, AFR 185 heads, 24# injectors, FRPP Cobra intake , BBK 70 mil T body, FRPP 9 index timing chain, Graneteli 73 mil mas meter, BBK unequal shorties.
Also, the aluminum FW isn't necessary unless you're road racing. It helps acceleration out of turns, but makes your rpms drop faster, which most people don't want for street/strip use. Stay stock or steel. The aluminum DS will lighten your rotational mass on the drivetrain, but won't really free up any hp--and isn't necessary until you've done your chassis stiffening and suspension upgrades.
The inj's and pump will be a good addition and will give you room to improve, too.
jwog666
12-27-2021 08:09 PM
daltron
04-28-2016 08:10 PM
bradleyb
11-27-2015 07:50 PM
