amp light stays on
Old Apr 7, 2006 | 11:38 PM
infantrycav's Avatar
infantrycav
Default amp light stays on
my amp light is coming on(the one with the battery symbol), My volts runs around like 10v idling ever since i installed my electric fan, i have a 50watt amp that shouldnt even touch the gauge, the bulbs i run are the adanced fake HID 130watt simulated 80 watt actuall bulbs and i dont have fogs. The battery is about 3 months old but i havent done a parasitic draw test cuz i cant seem to find my dvom. I have pulled a lot of the underdash hvac wires when i deleted my heater box. the fan i'm running isnt even that high of amperage but the way I have it running now is hooked up to the ignition wire through a relay. I know i should buy a new thermostatic switch but the one that came with the fan sucked so i just hotwired it. The fan is fine since i put the new rad in today(no overheating anymore). I pulled the power from the fan and ran the car for a bit and when i shut it off the amp light turned off, but when i turned the ign. back on to roll up my windows the light came back on and stayed on with the ign. turned off! Any advice?new batt., new fan thermostatic relay so I'm not running it all the time and upon initial start up? I tend to get long winded(sorry). I need to find my damn DVOM!!!![:@]
Old Apr 8, 2006 | 12:14 AM
Tims 88GT's Avatar
Tims 88GT
Default RE: amp light stays on
is your fan on all the time?
Old Apr 8, 2006 | 12:44 AM
infantrycav
yeah its on with the ign. with the setup i have now, but I'm gonna switch to a new programmable thermostaic relay soon.
Old Apr 8, 2006 | 12:45 AM
Tims 88GT's Avatar
Tims 88GT
thats a lot of your problem. does the light go off if you rev the motor?
Old Apr 8, 2006 | 01:18 AM
gspfunk's Avatar
gspfunk
A 3g, 130amp alt. will fix that right up.
Old Apr 8, 2006 | 01:31 AM
Tims 88GT's Avatar
Tims 88GT
might just need new brushes. my fans pull 30amps i think. and i run the stock alt for now
Old Apr 8, 2006 | 01:35 AM
ckyguy68's Avatar
ckyguy68
i had that problem. the yellow wire coming out of the alternator plug was snapped. it is the voltage indication wire.
Old Apr 8, 2006 | 01:55 AM
infantrycav
so your problem CKYGUY was it just the light coming on cause it sensed a fault or was there actually a problem? The fan is like 2months old and has maybe 500 miles on it so i dont think its the brushes. I dont like the fact that the fan is on and taking amperage while i'm starting the car, but i'm gonna change that soon.
Old Apr 8, 2006 | 01:58 AM
maverick771's Avatar
maverick771
sounds like you might have a bad voltage regulator... Is it made into the alt. or is it a old style.. did you arc any wires when you took out the AC stuff
Old Apr 8, 2006 | 02:01 AM
Tims 88GT's Avatar
Tims 88GT
no maybe you need to put brushes in the alt. not the fan.
jhawkr
Oct 30, 2015 01:55 PM
daytooday
Sep 20, 2015 10:55 AM
Colin Ringle
Sep 15, 2015 09:27 PM
MusicCity615
Sep 12, 2015 07:05 AM
cbird1177711
Sep 3, 2015 08:43 PM
