which mas works best?
I know this subject has probably been brought up a million times before, but I need opinions. Right now I am running a Pro-M mas 19 lb w/ cold air. It makes my car run like crap. Anyone have a suggestion for a mas that works. I bought the Pro-M cause everyone I talked to said it was good. It might not be calibrated properly as it was bought used from ebay. I have read good and bad things about C&L. What about Summit? I am going to get 24lb injectors eventually.. I'll do that when I do the heads. Anyone need a CAI? Got a Mac in fender... Brand new.
RE: which mas works best?
ORIGINAL: topless92
I've read posts about clocking the MAF. I can only go counter clockwise with mine because of the wiring harness length. I put it on the first time and it ran poorly.. I moved the idle up and changed the timing... Put it on and it ran good for a day. It then started reverting back to running poorly when driving especially. Took it off and put stocker back on.. Runs great. I did try moving the Maf a little... Didn't really change. I will, however, give it one more chance when I get my C&L inlet pipe.
09-01-2015 08:16 PM
