SERIOUS PROBLEM PLEASE HELP
RE: SERIOUS PROBLEM PLEASE HELP
really? because if that is the case then i am soooo glad. i needed someone that has had this expierience. when i changed my h pipe, i noticed the o2s looked pretty cooked. is there a way i can clean them? because i wont have enough $$$ for them until friday.
ORIGINAL: rmodel65
mine did this when my o2s went bad it would buck and pop i was getting a lean code
CkyGuy, Dunno if you checked this out yet. Just recently i was having what seemed to be a similar problem, After checking wires, spark plugs, upping my fuel grade and adding all kinds of additives, i broke down and looked into a haynes manual. First thing on that list was "Change your fuel filter" I did that just today, and bam, car is running fine again. Feels a bit faster too. The part is cheap, here in georgia it cost only 7 bucks. It was a bit of a pain in the rear to get to but otherwise quick and easy. If you haven't yet, check that out.
did u ever trade mafs? the whole thing sensior and all? if not find someone in the area and barrow theres. also i dunno about u all but if i unplug my maf when the car is running it dies. if i unplug it than start the car and try to drive it, it dies. so how are u going to run it with the maf unpluged?
stangin1996gt
09-21-2015 11:01 AM
ccdguy
09-19-2015 05:20 PM
09-03-2015 07:14 PM
