C&L accurate?
C&L accurate?
http://www.cnlperformance.com/76mm_94-95cobra.html WTH thats crazy if you look at the dyno. It says its on a basically stock 95GT auto. I can believe it cause the stock numbers arent that high but that is a nice improvement in performance. Do you guys believe it?
RE: C&L accurate?
HEY GUYS WITH C&L Is the chip on the top of the MAF the same as the stock, as in the screw holes and such? Cause I can get the one for 19lb injectors or for 24lb injectors and it would be the same price. Now if it is the same size then I will get the one for 24lb injectors but just switch the 19 on until I need the 24's. Or is it something else?
RE: C&L accurate?
i dunno if i believe that or not. i guess it could be true. I've been reading about C&L meters for the past few weeks on mustangtuning.org i think, and a few guys made charts of all the calibration tube diameters. they're showing that some of C&L not holding their tubes to a very tight margin of error or what, but that would explain why a lot of people hate C&L meters.
As for the performance, I put a 73mm maf on my stock 90 GT along with pulleys, CAI, and no air pump.. I definatly felt a change with it on. It accelerated a lot quicker and felt like it had alittle more torque. They're pretty tempremental meters though.
RE: C&L accurate?
ORIGINAL: Crazyfast50stang
It bolts up the same.
Yes, it will work w/ many injector sizes by changing the flow tube to match injector size.
RE: C&L accurate?
ORIGINAL: PRO50SC
Yes the electronics are from the stock unit.
Ok so you have to change the flow tube not the electronics yes? Also what else is out there other then C&L when it comes to this type of intake? I want to explore more. I dont want JUST the MAF I want a whole assembly like they have.
