best fuel pressure and idle problem
Old 04-22-2006, 11:20 PM
zex92mustang
zex92mustang's Avatar
Default best fuel pressure and idle problem
just put in a ecam 1.7 RR and ported e7 now im at 10:2 comp, the car will not idle, it will with a vac leak, but i need to know the best fuel pressure to run, with my stock regulater i was leaning out after 5000 rpm a bit, but now i can change it with my new AFPR, what the best place to start, thanks
zex92mustang is offline
Old 04-23-2006, 12:12 AM
AdderMk2
Banned
AdderMk2's Avatar
Default RE: best fuel pressure and idle problem
i wouldnt run any higher than 40psi with the vac line off. typically it should be lower that that, but it seems like you should just take your car to a performance shop and let them fix it
AdderMk2 is offline
Old 04-23-2006, 12:25 AM
Tims 88GT
Tims 88GT's Avatar
adjust the idle screw on the tb and start at 39psi with vac off.
Tims 88GT is offline
Old 04-23-2006, 03:59 AM
philthy89fifty
philthy89fifty's Avatar
when you say with the "vacum line off" should both ends were they were conected be plugged? i know it's a stupid question.
philthy89fifty is offline
Old 04-23-2006, 04:00 AM
Tims 88GT
Tims 88GT's Avatar
no just take it off the manifold, adjust the pressure and put it back on. dont for get to tighten the lock nut.
Old 04-23-2006, 12:01 PM
TBird232ci
TBird232ci's Avatar
If your car is leaning out in the upper RPM's, its not the pressure regulator, its the fuel pump.
TBird232ci is offline
djbigskrilla
09-20-2022 01:04 AM
mstahoo
SVT Forums
08-19-2021 09:15 PM
MEISTERSNFB
03-31-2020 07:50 AM
Scottyboy187
SVT Forums
09-02-2015 10:12 AM
timeformiller44
08-26-2015 12:03 PM
Quick Reply: best fuel pressure and idle problem
