mechanical fuel pump...
on my carbed car, I run a edelbrock mech fuel pump, with a big earls inline filter, between the pump and the carb, I ripped out all the stock lines and such and ran one 3/8 braided line up from the fuel cell, has been problem free since I did it last year.
you can mount it on the lower firewall or on the frame rail..etc....use a wire going to the oil sending unit so if oil pressure goes below 10 psi the pump shuts off also you can use a toggle switch and locate it in the ash tray area which could be hidden from view also a theft thing
ORIGINAL: tinner7
ORIGINAL: 2 kwik
mrappe
Sep 26, 2015 10:16 AM
