18’’ rims
Old Feb 18, 2003 | 12:14 AM
racing333's Avatar
racing333
Default 18’’ rims
I have a 1990 5.0 that I am starting to modify and need some information on how to get 18" rims to fit under my mustang. I cant stand it when I see people destroy hundreds of dollars of tires due to rubbing. I want to make suspension upgrades to lower the car but dont know how low I can go without rubbing. Also some info on the 5 lug conversion process.
Any info would be thankful.
Old Feb 18, 2003 | 12:52 AM
noslow50's Avatar
noslow50
I ♥ Acer
Default 18’’ rims
wow u got alot planned for this car huh??? well let's c the only real way to get 18's to fit is basiclly start with saleen rims.. for those u need the 5 lug conversion.. to do that u need almost the whole entire rear end of a sn95 body.. jsut about the same with the front... then u need springs.. i'm not too familar with the foxbody and rubbing issues, when it coems to tires.. i know that i haven't seen too many people put 18's on a fox...if u can i'm pretty sure they arn't going to be very fat... well good luck..
Old Feb 18, 2003 | 04:29 AM
spike306's Avatar
spike306
Default 18’’ rims
i can't really help w/the modification to 18's, but if your really into racing, i would just stick to the good ole 17x9's. unless your making an all out drag car. let me know how mod work out!!
Old Feb 18, 2003 | 02:33 PM
lloydchristmas's Avatar
lloydchristmas
Default 18’’ rims
Biggest Ive seen a a driveable fox is 17" And they look great. Id stick with them
Old Feb 18, 2003 | 09:41 PM
racing333's Avatar
racing333
Default 18’’ rims
Thanks for the info. Now that I know that putting 18s on would be more work than what its worth, I think I will stick to the 17". Wich brings up another question, what is a good rim width and tire size combo? Someone mentioned 17x9, is that the front and back? Will I still have to eliminate the quad shocks in the back?
Thanks again, Racing333
Old Feb 18, 2003 | 09:52 PM
spike306's Avatar
spike306
Default 18’’ rims
17x8 in the front, and 17x9 in the back. check ebay, they have some pretty good combo deals that come with tires
Old Jul 29, 2004 | 10:35 PM
shanesmustang's Avatar
shanesmustang
Default RE: 18Â’Â’ rims
you should also check www.wheelmax.com or a site like that. they usely have really good deals with both rims and tires
drfister
May 3, 2018 10:38 PM
whatsup62
Oct 16, 2015 03:07 PM
Jwoolsey08
Oct 2, 2015 08:42 AM
kdryan
Aug 21, 2015 04:01 PM
Mr. D
Aug 17, 2015 09:53 PM
