Oxygen Sensor wires...Which 1?
First off i have a 94 mustang gt, and i got a autometer air fuel ratio gaue. It says to splice into the sensor signal wire. My question is which one out of the 4 is the signal wire. The colors of the wires are red, black, gray&yellow, and gray. Which is the signal, Thanks in advance guys.
RE: Oxygen Sensor wires...Which 1?
LH side O2 signal = Red/Blk
RH side O2 signal = Gry/Lt Blu
Check ECM pins 43 & 44 of this diagram. Hope this helps.
Typical Ford's diagrams snafu.....check the wires at the O2 sensor side....you should have 2 white wires, 1 black and one gray....mate the black wire from the O2 side to the wire on the harness side....that's the signal wire....at either side. GL
jwog666
12-27-2021 08:09 PM
