Head gasket question
Im ordering a new set of fel-pro head gaskets. When placing the order it asks for quantity. I obviously want 2 of them, but my question is, are both sides the same exact gasket(shape and fit) I know this probably sounds like a stupid question.
RE: Head gasket question
Also, I cant seem to find head studs for the afr 165's. AFR recommends studs for these heads, but i cant seem to find studs for the 7/16 threads. Anyone know of a part number, or where i can get these?
Will these studs work with my setup. I found them on summit. Also should I put permatex sealer on the studs when installing?
Brand: ARP Automotive Racing Products
Product Line: ARP Cylinder Head Stud Kits
Fastener Style: Stud
Thread Size: 7/16 in.
Head Style: External hex
Fastener Material: Chromemoly
Fastener Finish: Black oxide
Washers Included: Yes
Washer Style: Flat
Cut to Fit: No
Quantity: Sold as a kit.
Notes: Undercut stud design for higher tensile strength.
Cylinder Head Studs, Hex Head, Ford, 289-302, 7/16 in., Kit
Check to make sure this part fits your application
Washer Style: Flat
Cut to Fit: No
Those sound like the ones I bought. ...and yes, use loctite when you screw in the studs, but not on the bolts once the heads are on. I'm not questioning your intelligence, just making sure you knew that.[sm=smiley36.gif]
EDIT: How much are they on summit? I think mine were $76 shipped off ebay....
Luke9222
10-22-2015 11:55 PM
