What are the symptoms of a faulty TAD or TAB Solenoid?
RE: What are the symptoms of a faulty TAD or TAB Solenoid?
ORIGINAL: TENGRAM
well, i switched o2 sensors and still got the code 94 so, it appears the o2s are not the problem.
i took the crossover pipe off and it was completely clogged on the driverside, the passenger side was 90% clogged.
i thoroughly cleaned all (most) of the carbon out of the pipe and the ports (blew through the tube to check it, its clear) then reinstalled the pipe. no difference, still get the KOER 94...[:'(] this is driverside, right? i'm starting to suspect the wiring now. anyone have any ideas what this could be?
69MustangCoupe393cid
10-03-2015 10:33 AM
