Turbo Track Times...
#33
RE: Turbo Track Times...
ORIGINAL: Dirty Sanchez
turbostang21, what manual tranny do you run??
"race prepped" tko 500....has high nickel alloy gears all crynogenically treated, deburred syncro rings, T6061 alum. shift fork, welded cluster gear = semi pro shifted, hardened keyway, and some other things i'm sure. it's supposed to be good for 700+fl lbs....it's been over that but after the next tune we'll see how it holds. i just put in a spec stage 5 clutch the other week. it works really well but it is made of cintered iron and has no springs (race only....) so it doesn't like or shouldn't be slipped. its basically in or out. it holds the power well but it squeaks like a belt...so other people think either something is wrong or that i'm peeling out every time i start out i was warned of this but i didn't think it would bother me, but it does a little bit. i'm starting to think i should've "bucked up" and got a mcloed twin disc...oh well live and learn[&o]
#34
ORIGINAL: turbostang21
#35
Talk about some "money". Worth it from everything I've read though.
mungodrums
09-28-2015 10:54 PM
mungodrums
Suspension
09-24-2015 10:12 PM
