Rear main leak/oil consumption?
RE: Rear main leak/oil consumption?
ORIGINAL: 92hatchLX
Mine does the same thing, it leaks, but I'm just ignoring it until I get my stall, which I'm going to order within the next two weeks depending on how this new job goes.
What does it mean if ur car is consuming oil and u have a smoke coming from ur exhaust. Not a whole bunch but when i punch it i can tell and also when i have been sitting with the car running for a lil while.
ORIGINAL: 5.0carlo
Incidentally, I just realized that an oil leak I thought I'd fixed is actually still leaking. My oil drain plug insists on leaking, even though I just replaced the washer with a nylon/plastic one from Ford. Hopefully when I get this leak stopped, I will notice less oil consumption.
ORIGINAL: g2_5point0
my drain plugs leaked for a bit. i went back under and tightened them like hell (not too crazy though) and now they're good to go
If you were losing 1 quart per 1000 miles due to a leak, it would be noticable. If you have ever spilled or dumped a quart of oil on the floor, you will amazed at the area it will cover. I am in about the same boat as far as using oil and no leaks. My motor area is basically dry...no drips...but I still use about a quart every 1000 to 1500 miles and my plugs look good too. I don't notice a ton of smoke either, but I am sure that a worn motor is the culpret in my case. I have about 120,000 miles, probably half of them the tires were spinning I replaced my valve seals last winter with hope of fixing it, but no luck...still have good compression, but I feel a rebuild in my future, just not sure on how soon
ORIGINAL: 5.0stanger
By the way, does anyone know why I can't find my old post on nylon/plastic drain plug washers from a couple of weeks ago? I've tried a bunch of searches, but nothing comes up.
ccdguy
09-19-2015 05:20 PM
