Air Conitioning
Old Jun 8, 2006 | 04:23 PM
  #31
Frebius's Avatar
Frebius
Default RE: Air Conitioning
Ok I will go ahead and try you test for the LP switch. If I am looking at needing a new compressor how much would that usually run at a shop?
Old Jun 8, 2006 | 04:27 PM
  #32
Bad Karma's Avatar
Bad Karma
I was thinking worst case scenario mentioning the compressor. Between $150-250 I would think. I've seen some I thought wouldn't be much being around $300 and some that we big and thought would cost alot be $145. Definitely shop around once you get a good diagnosis.
Also, there are other components that may be failing instead that's why I was thinking of you taking to someone who could bench test it for you and give you a good idea based on what their machine told them.
Even if they want to charge you $50 for the test, it would be well worth it because you could jump right on EBay and find a reman whatever it is you need for lots $ less.
Let me know if the LP switch test works for you.
I'll keep my fingers crossed.
Good luck,
Ivan
daltron
Apr 28, 2016 08:10 PM
Lethaldosage423
Oct 19, 2015 12:12 AM
Dokilar
15
Oct 16, 2015 08:13 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
1996cobraconvertible
SVT Forums
Sep 30, 2015 02:01 PM
