Horrible Noise
06-11-2006, 02:03 AM
RE: Horrible Noise
put rags in the tips if its a leak the noise will get louder
06-11-2006, 02:10 AM
RE: Horrible Noise
Quote:
ORIGINAL: Bagitupbaby
how bout if i spray carb cleaner on it would it do anythin?
it might start a fire.
Quote:
ORIGINAL: 351foxstang
first time i've heard that one, sounds like it would work well.
06-11-2006, 02:52 AM
I ♥ Acer
RE: Horrible Noise
just hope theres no backfire or ur cars goin up in flames lol
06-11-2006, 04:54 AM
RE: Horrible Noise
mix water and soap and use a brush and put it on all of the fittings, if it bubbles you have a leak if not you dont.
06-11-2006, 04:55 AM
RE: Horrible Noise
i had a clicking noise from the exhaust manifold/headers
it was blown header gaskets
when does it do this?
06-11-2006, 05:01 AM
RE: Horrible Noise
run Seafoam through you pcv line. have someone stomp on the gas while you check for white smoke around your exhaust.
This is how I found out I had a leak at the flange.
bjdutch2005
03-24-2017 03:38 AM
KingRando
10-02-2015 08:06 AM
69Volunteer
09-30-2015 10:39 AM
GLOCKer
09-28-2015 07:36 AM
