how does higher timing..
Old Jun 13, 2006 | 05:02 PM
  #21
leadfoot1988's Avatar
leadfoot1988
Default RE: how does higher timing..
this is base timing your talking about right
Old Jun 13, 2006 | 05:11 PM
  #22
Frebius's Avatar
Frebius
Yes only base timing.
Old Jun 13, 2006 | 05:13 PM
  #23
giddyup91's Avatar
giddyup91
So if your timing is advanced would you need to change out your plugs and wire more often?
Old Jun 13, 2006 | 05:21 PM
  #24
Frebius's Avatar
Frebius
no
Old Jun 13, 2006 | 05:32 PM
  #25
Frebius's Avatar
Frebius
It is actually a lot more "advanced" than 10*'s. 10* is the stock setting for the base timing. Which is checked when the Spout Connector is out. Then the Computer adds timing depending on load and RPM's. You "total timing" can be as high as 40*'s BTDC.
ORIGINAL: AdderMk2
ORIGINAL: Frebius
The reason you get more power is becuase you are adjusting the *'s Before Top Dead Center that your plugs fire. 10* is stock setting. Most people set at 14* so it fires sooner. What this does it ignite the fuel sooner. The closer you can get it to TDC the better because it will push down harder on the piston. If you do it to early you get detination and that is not good either. Detination is where the Piston is still on the way up and you ignite the fuel and it tries to force the piston back down while it is still traveling up.
actually thats called pre-ignition. Detonation is when the fuel ignites itself due to cylinder temperatures and pressure.
however... to answer the question about why the factory ddint set it higher.... well.. they did
its 10° advanced... instead of 0
Old Jun 13, 2006 | 06:58 PM
  #26
nitrous_bob's Avatar
nitrous_bob
i believe 10* base timing = 26* total timing (but i could be wrong, i am about 90% certain though)
if your car is not pinging don't add more octane, you will actually lose power w/ more octane/same timing
you want to run as lean as safely possible, to get the most power, most add octane for safety, some think it makes more power which it absolutely DOES NOT
i safely sprayed 80 hp on 14* base timing the other night w/ 93 octane which proves that NA stock motor could run 14* w/ on 87 as long as it's cool out, but sub-regular 85 or 86 ? your starting to push it.
you don't always hear detonation, lots of times have to read the plugs to see that it's happening.
or power time the car, bump 2* per run til your mph starts to slow down, pay no attention to ET, just MPH. use the setting that the mph was fastest.
Old Jun 13, 2006 | 07:07 PM
  #27
cepowers18's Avatar
cepowers18
I have my timing set to 12* with 93 octane and sometimes I get a hint of detonation (I think). Anyone have any suggestions?
Old Jun 13, 2006 | 08:09 PM
  #28
Frebius's Avatar
Frebius
Running it down the track is a very good way to judge it. That is how I did mine last week. It takes a few runs but at least you know you got it right.
ORIGINAL: nitrous_bob
Old Jun 13, 2006 | 08:33 PM
  #29
boss429's Avatar
boss429
haha, weeew i guess i was right, it's a long stretch
but i was in the right ball park lol
Old Jun 13, 2006 | 08:42 PM
  #30
Stevens91gt's Avatar
Stevens91gt
ORIGINAL: boss429
no u werent
ur not even in the same country man
