MIL elminator, and speedo gear
Heyall I am new to the mustang world and got my self a 90 GT, I am currently replacing my cats for E -test and got a BBK X pipe with cats, I also got 2 new oem O2 sensor, will this still need the mil eliminator to have normal functioning? or since I am still using stock O2's are they not required?
second the car came with 373 rear end gears in a 8.8" I am currently trying to find teh right speedo gear to go with it, does any one know were to get them or what specific one i need? oh sorry its also an AOD tranny
RE: MIL elminator, and speedo gear
Speedometer Gear Help Guide:
Ring & Pinion Speedo Gear Part Number
1983-89 Mustang Manual 5-Speed
3.08 18 Tooth LRS-17271H
3.27 19 Tooth LRS-17271A
3.55 20 Tooth LRS-17271B
3.73 21 Tooth LRS-17271C
4.10 23 Tooth LRS-17271D
1990-93 Mustang Manual 5-Speed
3.08 20 Tooth LRS-17271B
3.27 21 Tooth LRS-17271C
3.55 23 Tooth LRS-17271D
1984-89 Mustang Automatic AOD
3.27 19 Tooth LRS-17271E
3.55 20 Tooth LRS-17271F
3.73 21 Tooth LRS-17271G
4.10 23 Tooth LRS-17271J
1990-93 Mustang Automatic AOD
2.73 19 Tooth LRS-17271E
3.08 20 Tooth LRS-17271F
3.27 21 Tooth LRS-17271G
3.55 23 Tooth LRS-17271J
1996-98 Mustang Cobra Manual 5-Speed
1994-98 Mustang Manual 5-Speed
Except 1996-98 Cobra
1994-98 Mustang Automatic AOD
ORIGINAL: LondonGT
http://steeda.com/store/-catalog/speedometer.htm, check this out and do a search for the past 6 months on speedo gears etc. you'll find a ton of good info... good luck !
hey thanks for all the speedo gear help, I did some online calculations, and it says with my tier size and the fact that 90 AOD's have a 8 drive tooth I need a 23.8 to go with my 373 and 235 45 17's. so I assume 23 is the closest I can get, and thanks for the O2 help, so its just run the O2's like normal
KingRando
10-02-2015 08:06 AM
junior04
09-28-2015 10:53 AM
