intakes
RE: intakes
THERES A DYNO TEST IN A RECENT MUSCLE MUSTANG AND FAST FORDS. IT WAS RIGHT THERE WITH ALL THE TOP INTAKES. HAD VERY STRONG UPPER RPM. ALSO TESTED ON A 331 OR 347 CANT REMEMBER AND PERFORMED EVEN BETTER
. SO FROM WHAT THEY SAID FOR A TOTALLY STOCK MUSTANG MAYBE A LITTLE MUCH, BUT STILL GREAT. AND ALSO PERFORMS EVEN BETTER WITH MODS
RE: intakes
ORIGINAL: matthewcowan
I think the BBK intake is too ugly. I was considering buying it, but it looks too funky.
RE: intakes
Hey guys how much horsepower with all these parts and also the intake
1. BBK 75MM THROTTLE BODY
2. BBK 75MM EGR PLATE
3. BBK Shorty Headers
4. BBK Off road H-pipe with no cats
5. BBK FUEL PUMP 255 LITERS/HOUR
6. Ford racing 30 lb injectors
7. BBK SSI Intake (honed out)
8. Ford Racing Aluminum Driveshaft
9. A/C eliminator
10. Smog pump eliminator
11. Ford Racing 3.90 gears
12. MSD 6Al Ignition Kit
13. MSD Blaster 2 Coil
14. MSD 8.5 MM wires
15. NGK spark plugs
16. MSD Distributor
17. King Cobra clutch
18. Rebuilt t-5 tranny world class
19. Pro 5.0 shifter
20. Steeda clutch cable
21. Hypereutectic Flat Top .30 pistons
22. lunati camshaft with Duration 284/292, Lift .500/.510
23. Hi flo oil pump
Block is bored .30 over and has stock crank
Heads are also ported, buit stock
9. A/C eliminator
15. NGK spark plugs
16. MSD Distributor
19. Pro 5.0 shifter
23. Hi flo oil pump
RE: intakes
ORIGINAL: duslep
9. A/C eliminator
15. NGK spark plugs
16. MSD Distributor
19. Pro 5.0 shifter
23. Hi flo oil pump
9. A/C eliminator
15. NGK spark plugs
16. MSD Distributor
19. Pro 5.0 shifter
23. Hi flo oil pump
RE: intakes
ORIGINAL: stanglx2002
So how much boost are you going to be running? Also what is the compression ratio on the engine to be running that much boost?
ORIGINAL: duslep
9. A/C eliminator
15. NGK spark plugs
16. MSD Distributor
19. Pro 5.0 shifter
23. Hi flo oil pump
9. A/C eliminator
15. NGK spark plugs
16. MSD Distributor
19. Pro 5.0 shifter
23. Hi flo oil pump
RE: intakes
ORIGINAL: Mustangkiler
just looks lil goofy for my taste.
jwog666
12-27-2021 08:09 PM
daltron
04-28-2016 08:10 PM
bradleyb
11-27-2015 07:50 PM
