Gas mileage sucks A$$!!!!!
RE: Gas mileage sucks A$$!!!!!
heres the link to the sticky https://mustangforums.com/m_1531258/tm.htm
have u ever really checked the gas milage? filled the tank all the way up then drove the car untill u fill it up again later in the week and do the math? try doing that and see what the milage really is. i average 160 to a tank but thats because i play with mine a lot.
take alook at this link, this may help both your idle and gas mileage, it may help...
http://www.muscularmustangs.com/maintain.php
Also make sure your MAF is calibrated to the injectors your runining so that you have the proper air/gas ratio....
you guys are funny you give this guy a lot of maybe this will work besides looking at the real problem. Low Gas Mileage so that means fuel right. You replaced all the ignition stuff what about the fuel stuff like FUEL FILTER!!!!! If clogged fuel cant go though so the engine and the fuel pump work harder to pump more fuel. I would start there and see if that helps
bradleyb
11-27-2015 07:50 PM
