Alternator ques.....
RE: Alternator ques.....
When my alternator went out on my '90 the stock replacements were either 80 or 85 amps. I went with the 85. But my car is stock with only a small amp (and I'm an old fart that doesn't tend to crank it up 'cept every now and again).
And for Randy;
Watts is power, amps is current, Volts is potential. Volts X Amps = Watts, so at 13 volts an implement pulling 2000 watts would take 153.846 amps and something pulling 650 watts at 13 volts would take 50 amps. Naturally the Wattage rating of audio systems is peak, and not what they are pulling all the time.
And for Randy;
i say go with at "least" a 100 amp if anything. personally i'd go with the 130 as the others have mentioned. the underdrive will lower the charge anyways so why go for an alt that is just a little over stock. if you upgrade to the MSD stuff too down the road at least you won't have to get a another new alt or ditch the underdrive set up if you go with the stronger alts
ORIGINAL: 90GTRagtop
And for Randy;
And for Randy;
ORIGINAL: PRO50SC
Like 65[:@]
These should help point you in the right direction.
http://www.fordmuscle.com/archives/2...e/index2.shtml
http://www.corral.net/tech/maintenance/130a-tech.html
http://www.mustang50magazine.com/howto/22139/
Like 65[:@]
I have pics of my install...I was going to do a walkthrough and never got around to it. Maybe I'll have time tonight...
BTW, you can get a stator connector (which you need to do it RIGHT) from PA performance for $8 shipped.....
ORIGINAL: randy78045
ahhhh... youre one of em i need ta shoot for sharing your fukin music with me at the stop light??? [sm=violent053.gif]
ORIGINAL: P Zero
My amplifier for my sound system in the car. 2 12" kicker Comp Gold series, motorola 8" horn tweets, all running off of 2000 watts.
-P.
-P.
ORIGINAL: 1fastzook
im going to need a bullet proof vest if i get near randy. i only have 6000 watts
ORIGINAL: P Zero
-P.
-P.
Golfsito
10-06-2015 11:02 AM
mrmrultimate
Texas Regional Chapter
09-10-2015 09:43 AM
