bolt on subframe
Old May 6, 2004 | 10:10 PM
nemethjames1's Avatar
nemethjames1
Default bolt on subframe
those ford motorsport bolt on subframe connectors... do the bolt holes already exist? or do you have to make them? how hard are they to instal? whats the bennifits to getting a them welded on? thanks. -james
Old May 6, 2004 | 10:15 PM
NOS/MAN's Avatar
NOS/MAN
I ♥ Acer
Default RE: bolt on subframe
dont know about the holes but get them welded too.makes it ahole lot stronger..stiffer too.
Old May 6, 2004 | 11:22 PM
rookie22's Avatar
rookie22
how much does it cost, i got subfram connectors too and if i get it professionally dont how much money am i lookin at
Old May 6, 2004 | 11:34 PM
vfast's Avatar
vfast
I ♥ Acer
I'd say about 50.00 or so...the weld on are much better than putting holes into a frame on which your trying to stregthen right?
Old May 7, 2004 | 12:36 AM
fantasyfords's Avatar
fantasyfords
I just got mine installed tuesday. They were bolted and welded. Cost 75 for install.
Old May 7, 2004 | 01:54 AM
VertStangGT86's Avatar
VertStangGT86
Yea, def get them welded, you could probably even take them to a muffler shop or something and have them weld them up if dealers seem too expensive.
Old May 7, 2004 | 11:22 AM
WNDSOR's Avatar
WNDSOR
yeah get those welded if you can, you have to drill the holes for them. pretty easy to do if you have an angle drill, just have to move the fuel line out of the way.
Old May 7, 2004 | 04:35 PM
roundman's Avatar
roundman
definitely go with the welded installation. I got mine done at a performance suspension shop for only $100 bucks and they did a really good job of welding them on without drilling any holes in the sub frames. they really help stiffen the chassis up for better handling on the street and better weight transfer on the strip.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
baddog671
Jul 26, 2016 01:20 PM
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
2poor4u2
Sep 26, 2015 11:08 AM
maestro1024
Sep 21, 2015 02:40 PM
