Top End
Top End
ok im lookin at AFR's 185 cc outlaw aluminum cylinder heads, 42# injectors 255 lbh fuel pump, and looking at a 331 stroker kit, i need help with what type of intake i should get and will all of this hold up on a stock block??
RE: Top End
42# injectors is overkill unless ur running a power adder
24# should be fine
and yes the stock cast iron block can handle the power but i doubt the suspension will.
subframe connectors and U&L control arms are a must
24# should be fine
RE: Top End
Its as good as most any really. But its not the only one. Trick Flow Intakes are awsome also. The Trick Flow R might be a good choice, will out flow the Holly. But the Holly has always proven its self through out the full rpm range. RPM II is also a good choice.
