cable routing
cable routing
im installing my rebuilt tranny this afternoon does anybody know if the clutch cable as well as the speedometer cable go around the motor mount on oil pan side or on header side? im trying not to have to replace either cable if i can help it. thanks in advance
RE: cable routing
both cables are brand new. and i dont want to burn either one of them. so if i go on header side im going to have to tie them off to brake lines im sure. if i go around motor mount will i have enough lenght to reach my destination? thanks again
RE: cable routing
Clutch cable goes between the oil pan and header. Do yourself a favor and wrap that thing up in "heat wrap" or header wrap...something along those lines to keep it from melting. I wraped mine from the firewall to where it connects to the bellhousing.
RE: cable routing
Well there should be a hold down clamp for the cltch cable that bolts under the brake lines, as for the speedo you would have to have it about an inch away from the headers to be safe, you can get heat sheild tape to wrap around it to be safe, thats what I would do
RE: cable routing
ORIGINAL: Jay5oh
RE: cable routing
ORIGINAL: schwindty
Beat me to it damit
ORIGINAL: Jay5oh
RE: cable routing
thanks everyone for the reply. got my clutch installed, bbk shorties,and put everything back under my lx in 4hrs. glad its back to running strong again.once again thanks alot everyone.
jwog666
12-27-2021 08:09 PM
breaking
10-02-2015 01:27 PM
