I want to learn about heads.
PM Sent.....Black95MustangGT
Why the hating!!!! How come I can't attach certain links to other websites??
What gives, I thought that this was supposed to be a Tech Forum to help guys out??
Anybody know what's up with that?
-Ivan
-Ivan
ORIGINAL: MadMan@TheWheel
Bare heads are only good to get if you want to be responsible for putting them together, or having someone do so.
+1
Not worth buying bare heads unless you have good experience and aren't afraid to break something or spend more money later from breaking something.
-Ivan
What does it meen when it says "NON-Emissions" and what does it meen when it has Porting? Is that for special power adders or something? One says nitrous port. Without a special porting could you not add a special something onto it?
Non-emissions is a disclaimer about not intended for road use (in most cases it is a cya for the company)
Porting is the opening up of the Intake and Exhaust ports for added flow. I foyu have a cast head it removes the rough finish that causes pre-combustion chamber turbulence and robs HP.
Porting also improves shapes of the ports that is hard to mfg. with the casting process.
Simply put, it adds power which is the point.
LivingInThePast
Sep 16, 2015 12:20 PM
