Ball Joint HELP!!!
RE: Ball Joint HELP!!!
you have a jack stand or jack under the control arm, right? i think you have too but im just askin. i think what i did last time was found a big deep socket to slide over the ball joint stud but still thinner than the base of the joint so i had a bigger spot to whack at.
Got it out.... now getting the new one in using the press isn't so simple. It keeps wanting to go in crooked.
I'm wondering if i put it all back together and put the weight of the car on it........ it should pop into place?
ORIGINAL: preciousroy
rust penetrant and a bigger hammer
did you think of maybe going to your local part store and renting a balljoint press?
Boostaddict
2.3L Eco-Boost Tech
11-24-2015 06:11 AM
