ok, I'm honestly stuck
#22
RE: ok, I'm honestly stuck
if the penatrating oil dosn't work try the dremel, cut it with the cut off wheel then get a drill bit an drill out a small hole, and then use a real drill to drill out a bigger and bigger hole. belive me, a dremel can cut through a bolt.
#23
Did you contact Brian Rogers at BBK to get the studs? I know you would have to wait for them but they will be the correct studs. I would use a dremel and use a cut off bit to cut them. If you need the number for BBK PM me or email me and I will give it to you.
Matt's 95 Stang
10-05-2015 07:16 AM
DreadPirateRoberts
09-26-2015 02:11 PM
