how much tranny and rear end fluid?
RE: how much tranny and rear end fluid?
marketing dept. got you!
You can use any synthetic rear end fluid as long as the friction modifier is used as well, or included.
How is rear diff. fluid going to add HP?
ORIGINAL: 7upedition
In a limited slip rear differential it is required that a friction modifer be used to reduce the friction of moving gear parts, trak lok is Fords version of a Posi rear end. Internally, a differential is connected to the axle by way of a series of splines. In essence, the axles are connected via the splines to the axle gears or "side gears" inside the differential case. The side gears are engaged by the pinion gears or "spider gears," which are mounted on a common shaft assembly. Moving in a straight line, the pinion gears are stationary; there is no turning action on the pinion shaft. The side gears are driven equally, but when the vehicle turns, the pinion gears turn on the shaft. One half or side of the carrier then speeds up while the other slows down. The result is a smooth turn without one tire spinning. The purpose of the trak lok unit is to maintain additional force so that the pinion gears remain stationary unless absolutely necessary. When engine torque and power are supplied in a straight line, the clutches lock and drive both sides of the carrier equally, but when the vehicle is turning, the clutches become "unlocked," allowing for the previously described smooth turn.
It may gain you a hp or two but not significantly... if it works though use it i guess, right?
Check on the rear diff fluid you buy it will say if it has the rear diff additive in it already, if not then yes you need to buy it and put it in or else you'll burn the trak lok clutches out.
so in the T5, do i use automatic tranny fluid? people have told me to use it because it has less viscousity.
not sure i have an AOD and i use auto tranny fluid, try to do a search or create a new poll and ask people what they use in thier t5's, i'd use the manufacturers recomended fluid though... i'll see if i can find out for you... k
Check this link out they also recommend using ATF in the T5:
http://www.fordmuscle.com/archives/2...uild/index.php
sh*t, it kicked me out when i tried to access the third page, it said i didnt have an account. they said to use auto tranny fluid? did they say how much of it and what viscosity they used?
Dragonus18
09-09-2015 01:21 AM
09-01-2015 08:16 PM
