Ignition problem, need help!
Old Jul 28, 2006 | 07:21 PM
88blackCONvert's Avatar
88blackCONvert
Default Ignition problem, need help!
Ok, i parked my car a couple weeks ago (running great at this time) and went out to start it up today, and it wouldn't stay running. Heres the problem:
When i turn the key all the way to engage starter and fuel pump, the car cranks and starts right up, but when i let go of the key, it loses power to the gauges/fuel pump/ignition/blah blah. I can hold the key in a sweet spot by starting it, then easing back on the key just a bit and it will run fine (other than me having to hold the key).
Do you guys think it's the key switch, or something simple like a loose wire? I converted it to carb about 4-5 months ago, and haven't had any problems till now. Anyone else had this problem?
Old Jul 28, 2006 | 07:26 PM
lookinforastang's Avatar
lookinforastang
I ♥ Acer
Default RE: Ignition problem, need help!
sounds like a bad key cylinder
theres linkage on the end of it that is supposed to keep it engaged sounds like its not sticking
try taking it out
Meystang
Sep 25, 2015 04:05 PM
jessicarabbit
Sep 25, 2015 12:41 PM
pimp2303
Sep 17, 2015 08:45 PM
TfcCDR
Sep 14, 2015 12:08 PM
Wombatnation
Sep 13, 2015 09:16 PM
