1.6 Rockers
1.6 Rockers
I just picked up a set of Cobra 1.6 roller rockers for a VERY generous price (aka $10). I wasn't looking for them, but was buying LT's off the guy and he just wanted to get rid of them. What would be the result of putting these on my 5.0? Basically a stock engine, would it be worth it?
RE: 1.6 Rockers
My bad...meant to type 1.7. Anyway- what kinds of differences would I notice if I installed these on a stock engine? I know that the rollers reduce friction, so maybe a small hp gain? Also with the 1.7's would be a bit of an increase in redline, if I'm not mistaken. This is about all I know, if anyone can fill in more details it would be appreciated. I'm trying to decide if it would be worth it to tear everything apart and install these
RE: 1.6 Rockers
are you running the stock cam?
cam lift with 1.6 (stock rockers) = .466
cam lift with 1.7 (cobra) rockers .473
with stock heads mabey 2hp gain, with good heads (afr 165 or equelant) they have been show to add 23hp and 12 lb-ft with a stock cam (a aftermarket cam wont be so dramatic). the area under peak see higher gains, you can gain almost 30hp at 4,000 rpm for example/
69MustangCoupe393cid
10-03-2015 10:33 AM
JDWalton
09-24-2015 08:47 PM
