Intake question...
Intake question...
Aright, so i bought a 94 GT with a 302 out of an 89 gt. Car has no intake on it now. I picked up a fox body intake lower with the stock rails and injectors, will this hook up with all the fuel lines correctly in the 94? is it all the same? and should i be getting a throttle body and upper for a fox or for the 94? This is my first stang, so I have no idea.
RE: Intake question...
why put a stock intake back on it? You can get a used aftermarket setup for under 300 bones.
EDIT: Oh, and you will need an elbow unless you get an intake that came out of a sn-stang (94-95 cobra or GT).
The SN95 intakes and 91-93 tbird/cpugar are the same part number but beware thats the reason the SN95 had less horsepower than the fox, the intake runners on the upper are shorter for hood clearance. The stock intake sucks... alot get an aftermarket one you won't regret it.
my 95 has a 93cobra set up on it and works fine but had to make the air tube setup so it will work with a little creative thinking but on the same hand mine is going to get replaced with a bbk system with a elbo
jwog666
12-27-2021 08:09 PM
daltron
04-28-2016 08:10 PM
bradleyb
11-27-2015 07:50 PM
