what would the RWHP be?
if i put a intercooled supercharger @14psi, tfs twisted wedge heads, trick flow stage 1 cam, 1.7 roller rockers, holley systemax intake, 75mm TB, 42lbs injectors what HP would i have?
i will have BBK unequal headers and 2.5" exhaust with BBK o/r H-pipe and american thunder 2 chamber mufflers.
which superchager should be the best?
what size injectors?
RE: what would the RWHP be?
500ish rwhp or more
im making 461rwhp with the stock cam and 10psi of boost, afr 165's and 1.6rr. but i run a chemical intercooler and an aod trans
youll have to notch the pistons to fit the 185's
Swap that BBK SSI to a Holley Systemax and you'll pick up a considerable amount of power.
Yes, GT40P will fit. But if you were originally considering AFR 185s, TFS Twisted Wedge should be in your budget.
42lb injectors would be about right.
i want the ssi because it looks cool, but i was thinking of getting the twisted wedge heads too.
what do these heads go for?
and the holley systemmax what HP over the ssi would i get?
ORIGINAL: 92civy
u have an amazing car man
will i have to notch the pistons on gt40p heads also?
what injectors u running
i run 42# injectors but i also get fuel from my meth/water kit.
id buy either afr165's or the tfs heads if i was you. i have the 165's and they are great
09-17-2015 07:32 PM
09-16-2015 07:53 PM
