ECC-IV swap question
RE: ECC-IV swap question
A9L
This is the most aggressive (timing & fuel) computer which is available.
The X3Z (93 Cobra) will require changing the MAF and will not make more power.
Why do you want a new computer?
jason
jason
I think mine is burnt up. I drove thru a big rain storm yesterday, and my stang started sputtering and blowing black smoke. Its getting choke with too much fuel right. So I replaced the MAF and the ICM. Still does it. So I looked at the computer and the insulation around it was wet, water got inside that kick panel some how. And I cannot get any codes outta the computer. It wont even initate the KOEO test. Any ideas?
If water got inside your car, there could be any number of electrical problems.
I would have no idea where to start.
Did you let everything fully dry?
You will have to do some pin tests on the wire harness, I think.
If you simply plug in a good computer, while a fault still exists, you could end up with 2 fried computers.
This is probably bad "Mustang Forums" etiquette, but there is a guy on stangnet that will know how to check out the wiring. Go there and post your question in the 5.0 tech section.
When jrichker responds, you will have a good chance of finding the problem.
Good Luck,
jason
Good Luck,
jason
well awhile back i had the same problem,and to come to think of it. it rained the day before then all of a sudden my cel came on...couldn't get any codes or anything....so i put my a9p in and everything is back to normal,AND i can get codes which are all smog related.
jaiidutch
09-14-2015 10:29 AM
