MAF Conversion
MAF Conversion
i just got the chance to do my conversion today
i read somewhere that when using bigger injectors and a aftermarket MAF meter it could cause some driveability problems
the reason for doing this conversion is because i put a ford racing create motor in and it requires a minimum of 30lb injectors
i put 36lb injectors in with a proM 80mm MAF sensor(calibrated to 36lbs) because i got a good deal on them
its running kind of rough but im going to recheck the timing and adjust accordingly, probably advance it 15deg.
anyone have any other words of wisdom for me
RE: MAF Conversion
Doesnt the Ford Racing crate engine, (depending on which one) Come with a Cam in it? You sure it isnt just your lope in the cam your hearing? Or is it actually wanting to not run and cut off?
But i would run the codes also. THats the sure fire way to do it and you wont be chasing grimlins forever, it will let you know what up, you can fix it and be done with it.
jwog666
12-27-2021 08:09 PM
HRnB
GT350 S550 Tech
12-18-2015 09:35 AM
11-10-2015 11:39 AM
