steering wheel change
Im in the search for a fox body mustang, but would like a 90-92 cause of the air bag. I was just wondering if it is possible to take the entire steering column including the steering wheel from a 90-93 and put it into a 87-89. Thanks for the help.
RE: steering wheel change
You will need more than just the column for it to work. I would imagine that you would need impact sensors for the front and some sort of SRS module (safety restraint system).
-P.
-P.
If you trying to do it make it look different that's cool. If your doing to get air bags you might as well just buy a 90-93 5.0 so you won't have to go through all the sensor's wiring labor etc... It will become expensive and I'm pretty sure it's not worth the money. It's cheaper to get a removable steering wheel.
+1 Its alot of work and Im sure its more work than I/we even know about. Basically, if your doing it for the safety its just not worth it. For looks, than yes because its a simply swap.
