gauge lighting
Old Aug 17, 2006 | 08:18 PM
91lxstang's Avatar
91lxstang
Default gauge lighting
i have a autometer water temp gauge and i have it hooked up without the lights....... i need it to light up at night so i can see it.... i dont have a chilton manual and dont wanna buy one just yet so dont tell me to just look it up..... i just need to know which wires i splice into to make the gauge light up and which wire is the ground.... is the black or white the ground?? im guessin its the black but it doesnt say in the instructions and i wanna make sure..... also, i want the gauge to only be lit up when the key is turned..... so what exact wire do i splice into???
Old Aug 17, 2006 | 08:24 PM
93foxgt's Avatar
93foxgt
Default RE: gauge lighting
I spliced mine into my side marker lights, that way the light comes on only when I turn on the side markers. Black is usually ground but it doesn't matter, you can use either.
Old Aug 17, 2006 | 08:25 PM
88stangaruu's Avatar
88stangaruu
the white is hot and the black is ground. But splice the white wire into any wire thats coming off of your dimmer switch. You you can find the dimmer switch fuse and plug the wire into the positive side of the fuse and then put the fuse in ontop of it.
But it can be wired into any light source that comes on with the dash backlighting.
Old Aug 17, 2006 | 08:43 PM
91lxstang's Avatar
91lxstang
ill prob do the side marker .... thats a good idea..... which wire is that???
Old Aug 17, 2006 | 09:15 PM
88stangaruu
id just find the dimmer switch fuse and run it to that. THats what i got mine run to. Works fine.
Old Aug 17, 2006 | 10:19 PM
93foxgt's Avatar
93foxgt
^^ he has a better idea than me. I couldn't figure out which dimmer cable to hack into- I guess any of the 500 would have been fine :/
andrew1969
16
Jan 8, 2016 02:48 PM
SteelerNation82
Sep 16, 2015 07:11 AM
rksnow1
Sep 14, 2015 08:46 PM
MusicCity615
Sep 12, 2015 07:05 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
