gear choice.
gear choice.
hello guys i needs some advice. im running a small block stroker motor and it is a strickly strip car. with a 5 speed tranny. i want to upgrade my gears in the rear end...i currently have 373 in her now. i was thinking about changing to 456....i want to be able to run the quater and have a solid strong gear. what do you guys recommend...thanks for any advice.
RE: gear choice.
depending on what your max rpms are in that car, a 4.56 might hurt your mph in the 1/4, not to mention you might have to go to 5th and most of the time you dont want to have to shift to 5th in a 5 speed, at least thats the way i look at it, you want something your going to cross the line in 4th at about 5,700-6,000rpm.
RE: gear choice.
stangaruu is right, I am fine with my 373 but if you wanna go up, id suggest no more than 410. Like he said, you want your rpm to be right near the redline in 4th when you go thru the trap.
RE: gear choice.
thanks for the input guys. how well will the car launch with the 373...im going to put a spool and rear control arms on the car. will the 373 be good out of the hole with all the horse power im pushing. thanks for all and any advice.
RE: gear choice.
ORIGINAL: mallory
KingRando
10-02-2015 08:06 AM
junior04
09-28-2015 10:53 AM
