what MAF and TB should i get?
RE: what MAF and TB should i get?
i think i have figured out what i want to buy
70mm MAF calibrated for 19lb injecters
65 mm TB and egr spacer (which i might just bypass)
and a cold air kit for an 89 since i have a MAF
i'm half asleep so please correct me if i'm wrong
p.s. would i get more perfornace with 24ln injecters if i kept the heads and intake stock but got a differnt MAF and TB?
stock heads are restrictive performance wise, so i say get you your cold air induction and then save up for a set of heads. thats what i did and believe me it was well worth it. looking back I cant believe i waited this long, the differance really has no comparison. u really dont need 24# injectors because your stock injectors can handle up to around 300 hp. use the cash to get u some gears because that will get u the most performance for your buck.
it already has 3:55's and i relly dont want to go any higher then that becasue you start to run into drivabilty issues, since this is my daily driver, i doubt that i will ever put new heads on it, i'm looking for easy bolt ons for some power, but in the end i want to keep it as stock as possible.
jwog666
12-27-2021 08:09 PM
stangin1996gt
09-21-2015 11:01 AM
