MAC intake
MAC intake
when putting it in, is there an easier way to put it in without taking off the tire lol? i love it, they send you a filter that won't fit through the fenderwell whole. o welll thanks!
RE: MAC intake
you have to just stick your hand through the hole above the headlight and do it from there. Its not that hard... really. Its NOT supposed to fit inside the hole in the fender. And even if you dont want to do that.... just take the tire off like you said. You can take the tire off in about 2 mintues flat incuding jacking it up
RE: MAC intake
I was able to get it in from the bottom. Just remove the 2 screws holding the splash shield in on the front. That will give you enough room to slide the filter up. You need to stick the pipe into the hole first so you can slip the filter over it. Then just reach up there with a screw driver and tighten the clamp.
jwog666
12-27-2021 08:09 PM
daltron
04-28-2016 08:10 PM
bradleyb
11-27-2015 07:50 PM
