B303 CAM HELP PLEASE
Old 08-25-2006, 06:15 PM
94GTBLACK
94GTBLACK's Avatar
Default B303 CAM HELP PLEASE
IVE GOT A 94 GT WITH BBK HEADERS AND A COLD AIR INDUCTION KIT.
I RECENTLY AQUIRED A B303 CAM.
IS IT JUST A STRAIGHT UP INSTALL OR DO I NEED TO CHANGE VALVE SPRINGS?
I HAVENT BEEN AROUND FAST CARS FOR ABOUT 7 YEARS SO IM STILL TRYING TO REMEMBER ALL THE SMALL STUFF.
94GTBLACK is offline
Old 08-25-2006, 07:28 PM
05gtdriver
05gtdriver's Avatar
Default RE: B303 CAM HELP PLEASE
Are your heads stock? The B-303 cam was more or less designed to work in conjunction with the GT-40 heads. You'll see a performance gain with just installing the cam, but not as greatly as if the cam were allowed to work more effectively with better
breathing heads. I'd change the entire cam/roller lifters/valve springs to be sure. Is the cam new, or used? Then you have to think about upgrading your intake/TB/Mass Air/possibly injectors which necessitates a computer recalibration.....sorry if I opened a can
of worms. Maybe someone who runs a B-303 with stock heads can be of better help.....[sm=signs003.gif]
05gtdriver is offline
Old 08-25-2006, 09:21 PM
leadfootdriver
leadfootdriver's Avatar
YOu'll be fine with the valve springs. The E cam has more lift, but the B has more duration which is better for top end.
M-6250-E303 1985-95 Hydraulic Good idle quality. Excellent low- and 2500 5500 282° 282° 0.498" 0.498"
➂302 with Roller Roller mid-range power. Power through 6000 RPM.
Tappet Cam Tappet Emissions legal with 5-speed manual trans 220° 220°
➀➁(E.O. #D-225-16). Works well with automatic
E.O. #D-225-16 transmission. Great for superchargers.
M-6250-F303* 1985-95 Hydraulic Slightly rougher idle than E303. More 2800 6000 288° 288° 0.512" 0.512"
➂➃302 with Roller Roller mid-range and top-end power than E303.
Tappet Cam Tappet Great for superchargers. 5-speed manual 226° 226°
➀➁transmission recommended.
M-6250-B303* 1985-95 Hydraulic Fair idle quality. Good low-end torque. 3300 5100 284° 284° 0.480" 0.480"
➂302 with Roller Roller Significant top-end horsepower above
Tappet Cam Tappet 4000 RPM. 5-speed manual transmission 224° 224°
➀➁recommended.
M-6250-X303* 1985-95 Hydraulic Ultra high-performance camshaft. 3500 6200 286° 286° 0.542" 0.542"
➂➃302 with Roller Roller Fair idle quality. Big time torque and
Tappet Cam Tappet horsepower maker—up to 6200 RPM. 224° 224°
➀➁5-speed manual transmission recommended.
M-6250-Z303* 1985-95 Hydraulic “CamZilla” the biggest and baddest camshaft 3500 6500 290° 290° 0.552" 0.552"
➂➃➄302 with Roller Roller Ford Racing offers. Fair idle quality. Big time
Tappet Cam Tappet torque and horsepower maker—up to 6500 RPM. 228° 228°
leadfootdriver is offline
Old 08-25-2006, 09:26 PM
Logz5.0
Logz5.0's Avatar
Yeah, I have a B303 cam in mine, and it made a big difference even whthout anything else, but as they said, with all the right parts, it makes it that much more effective.
[IMG]local://upfiles/31237/1B43C7BB50B34483A9A6B0EC0E5F0262.jpg[/IMG]
Logz5.0 is offline
Old 08-28-2006, 03:24 PM
94GTBLACK
94GTBLACK's Avatar
THANKS FOR THE INPUT. I DO HAVE GT-40'S ON THE WAY INTAKE AND HEADS. DO IT ALL AT ONCE
Old 08-28-2006, 03:26 PM
88stangaruu
88stangaruu's Avatar
Throw some 1.7's on it if you want some big difference
88stangaruu is offline
GimpyHSHS
19
12-19-2023 01:12 PM
Stone629
The Racers Bench
66
06-02-2016 09:52 PM
patchshaffer
Tuner Central
10-05-2015 02:24 PM
uedlose
The Racers Bench
10-01-2015 08:31 PM
junior04
09-28-2015 10:53 AM
Quick Reply: B303 CAM HELP PLEASE
