C-4 ?'s
Old Sep 2, 2006 | 12:46 PM
oneslo50's Avatar
oneslo50
Default C-4 ?'s
I just installed a c-4 and 3500 stall in my car.The trans. only wants to take like 4 quarts of fluid.But it will go in gear and shift fine.I am being told that it ought to hold atleast 9-10 quarts.does anyone have any ideas why this is happening.Do you think fluid just haven't works its self everywhere yet.Thanks.
Old Sep 2, 2006 | 01:32 PM
Twister's Avatar
Twister
Default RE: C-4 ?'s
sounds like something was pre-loaded, but yes, 4 quarts is not enough
Old Sep 2, 2006 | 11:33 PM
Synyster Racing's Avatar
Synyster Racing
Default RE: C-4 ?'s
Did you put a quart of fluid in the converter before installing it? Once the car is running, C4's will usually take 7-9 quarts of fluid with a stock pan...
Old Sep 2, 2006 | 11:34 PM
Synyster Racing
Default RE: C-4 ?'s
the converter itself will usually hold 3 quarts
Old Sep 2, 2006 | 11:39 PM
PONY GUY's Avatar
PONY GUY
Default RE: C-4 ?'s
If you didnt put any fluid in the converter I hope the car want on for long you run teh risk of wiping the pump out but usallay after u fill the converter up and dump 6qts in the pan and run it threw the gears it will hold about 7-8 qts
amnlega
Jan 2, 2006 08:59 PM
Silver88T
Jan 31, 2005 02:19 AM
import slayer
Jan 21, 2005 01:10 AM
import slayer
Dec 3, 2004 10:04 PM
RAGNAROK
Jun 24, 2003 06:56 PM
