A9L computer
RE: A9L computer
ORIGINAL: richiemech
Anyone know if a '95 Mark V111 mass air flow sensor will work with a A9L computer? I also have the stock Mark V111 injectors which are 26lb. injectors and the fuel pressure regulator.
That number will help alot in deciding if it will work.
Also, you will want to measure the MAF tube diameter.
If the number and the size matches the 94-95 Mustang V8, then it will work. The 94-95 Mustang was a 70mm MAF with a F2VF MAS.
Otherwise, NO.
According to my Note sheet the 95 had a 80mm MAF, F3VF MAS, and 24lb Injectors.
jason
