1.7 roller rockers clearance ok? 5.0 ho 1990
RE: 1.7 roller rockers clearance ok? 5.0 ho 1990
dam it... what do i have to do to check it? or how do you notch the pistons? i know omeone on here said that it's easy to do yourself.
also would that cam be a good choice? i've heard some good things bout it
(sorry to steal your thread)
put a piece of clay in cylinder and turn over. with old head gasket on block and block bolted down two bolts/ you can see where the piston laps and almost touches the face, measure, the depth, after peeling off clay, .080 in ur fine
OR the engine will lock while turning, then u know
You can also test it without takin off the head. http://www.fordmuscle.com/fundamentals/pistontovalve/
Theres 2 methods there.
ORIGINAL: aode06
yeah thats what i thought, I figured I can at least get the 1.7 rollers and gain 30 hp, my machinist told me my stock cam is holding me back with my setup and I need to make it BREATHE, so Im assuming with my stock cam and some 1.7 rollers my duration and specs will be cobra?? correct?
