28 or 31 spline?
Old Jul 10, 2004 | 01:04 AM
Fishhawk's Avatar
Fishhawk
Default 28 or 31 spline?
I just finished the mod's on my 85 GT. I want to dump the 7.5 rear end for an 8.8 and am undecided on how strong I should build it. Without dyno testing the motor I'm guessing I have around 300 RWHP. The car also has the factory T5 trans. If I go with the 28 spline axle's I will save about $300 as I would still be able to use my stock one's. I've been told by a couple of seasoned racers that the 31 spline would be over-kill and to save the $300 to spend on something else. They say I just don't have the HP to justify the 31 spline. Also, because of the highway miles I drive would I be smarter to go with 3.55 gears or 3.73? Running the stock 2.73 now and spin the tires pretty easy
Old Jul 10, 2004 | 04:55 PM
NOS/MAN's Avatar
NOS/MAN
I ♥ Acer
Default RE: 28 or 31 spline?
GO 31 SPLINES ,,28 ARE WEAK EVEN FOR A STOCK STANG..SAVING $300.00 ISNT WORTH YOUR LIFE,, IF YOU BREAK AN AXLE???
Old Jul 10, 2004 | 08:41 PM
619socalstang's Avatar
619socalstang
MAN has a point and you can not run the c-clips anywayz, go with teh 31 spline.
Old Jul 10, 2004 | 09:03 PM
NOS/MAN's Avatar
NOS/MAN
I ♥ Acer
ORIGINAL: 619socalstang
i still got c clips in mine but 31 splines is alot stronger...i didnt know at the time i was going to break into the nines....know i will need no c clips ,,i waste more dam money let me tell you ...............
Old Jul 11, 2004 | 04:04 PM
roundman's Avatar
roundman
Keep the 28 spline axles for now and go with the 3.73 gears. The difference in gas mileage is negligible between them and 3.55 and the 3.73's are a lot more fun to drive.
And NOS/MAN you really need to lose those C-clip axles and get the proper axle retention types before you have a big accident.
Old Jul 11, 2004 | 06:21 PM
NOS/MAN's Avatar
NOS/MAN
I ♥ Acer
I KNOW A 9 IN IS IN THE WORKS SOON ,,IF I RUN MID 9S ARE BETTER ,,IAM JUST GOING TO LOOSEN MY ROCKERS,,AND PARK IT AND KEEP THE DIAL IN ON IT ,,,THAT WAY I WONT DRAG RACE IT EVERY WEEKEND AND HURT SOMETHING ON IT.....IT WILL REST FOR AWHILE ,,WHILE I REST I WHILE,,,,I CAN JUST SIT BACK AND THINK ABOUT WHAT IT RUN ,,LET IT SOAK IN ...YOU DO THAT ,,,LIKE DAM I CANT BELIVE IT ,,,
Old Jul 11, 2004 | 06:51 PM
619socalstang
REST IS GOOD.
spamedic
Sep 9, 2015 12:15 AM
Boostaddict
Lethal Performance
Aug 13, 2015 01:57 PM
jdaniel
Jun 21, 2005 11:54 AM
gt96stang
Mar 8, 2005 05:07 PM
mikes7950
Oct 24, 2003 03:12 PM
