detonation and CEL!!
So i was coming home from work the other day and decided to get on it a little bit.
it got to about 3500 rpm in second gear at half throttle when i heard loud detonation coming from the left side accompanied by a bad smell and lots of smoke.
then my check engine light came on. (it had been turning on/off prior)
my car has been running fine since if i'm easy but wil start to detonate again under load. i have not messed with the timing and can't verify it right now b/c i don't have a light.
i pulled plugs this morning and they all seem a bit lean except for number 6 which is extremely white. i guess that cylinder is detonating? why only that one?
also i tried to get my codes pulled but autozone and advance say they only do 96 and up[&:] (OBD II)
where can i get them pulled? NAPA?
thanks all!
thanks all!
RE: detonation and CEL!!
ORIGINAL: grabbem88
self test buddy....a little wire your small dio plug and a ground..i use hood hinge..turn key and count..
why only #6?....clogged injector most likely
cool.
could you elaborate on the self test? count what?
you can pull the codes yourself by jumping a small plug on the driver firewall
and then counting the flashes of the CEL to get the code number.
the computer can run a cylinder check thru this also where it will turn on and off
each cylinder and check make sure they are all firing properly.
Here's how you do it
http://www.corral.net/tech/maintenance/eecivtest.html
thats the link you need.
jwog666
12-27-2021 08:09 PM
